After 6 months of looking for a Fathom for <$4000 (shipped), one finally popped in the Bay Area a few weeks ago about 30 minutes from home. Somehow, I was first on the scene. A guy needed to move a few pins to get some cash, and I was the lucky recipient of the Fathom. Note to self: ALWAYS wait to buy from people who truly "need" to sell. Wait for "the guy" that needs "cash" or "space" and will sell at a reasonable price.
The previous owner put a Halifax PF (2004), and CPR BG (2011) + Plastics (2009) on there and got it clear coated. PF is very clean and sharp. No wear nowhere.
BG: 8
PF: 9- (It's a "bronze" level repro in terms of the inserts lining up, otherwise it's gorgeous, and has 0 wear spots.)
Cabinet: 5 (will need repaint for sure at some point)
Boards: 7 (MPU and Lamp Board need $2 in SCRs/etc. replaced, battery is already off-board)
Plastics: 9
Displays: 8 (strong and sharp -- but -- one digit out)
I don't even have to vacuum the cabinet... That's a first.
The Halifax PF is a hair narrower than the more modern CPR fathom PFs so you had to use shorter hex screws, haha, what a PITA...
From what I can tell everything on the playfield was tumbled and polished. There's not much to do there but make some playability adjustments.
Under the playfield, there are a few parts to sand blast and plate if desired:
* drop target assemblies and such
* transformer platform, etc
My short-term goal is to get Fathom into a really solid player state in 40 hours, and leave it until 2016 to redo the cabinet, etc -- after I have a few high end restores under my belt.
6 MAGIC KEYS TO A WELL-TUNED UP FATHOM
1. outlanes NEVER drain (re-position the ball guides with new holes for the hex screw if necessary)
2. inlanes can nudge-save (1/5) of the time or better. (So you feel like you have a "chance") -- (adjust rubber and location of post until it's perfect, use a small washer under base of post for increased stability)
3. all inline drops are flush with the playfield
4. make sure all rollover stars can go flush with the playfield when a ball rolls over it (carve the plastic of the STAR if needed)
5. make sure the upper flipper is laying as flat as possible
6. make sure the orbit exit is flush from wire guide to rubber (re-position the ball guides with new holes for the hex screw if necessary)
-mof
