I completely removed my Loki Lock plastic and the 3 bulbs. Attached are pics of the sight lines now in the area, and it is MUCH better. You can actually see all 3 of the SHIELD targets now, and can make a calculated shot for Nick Fury, which is where you collect your random awards.
It also really de-clutters the PF. Anything that makes it feel a little less busy is a plus, IMO. The ball lock is physical on this machine, so you don't need a light to tell you how many balls are locked. They are literally right there under your nose on the right side, closer than the lock lights. The only drawback is that you won't have the bulbs flashing to indicate that Lock Is Lit. But there is a good bit of animation and a callout to alert you that it is lit. Also, once you light the lock, all 3 are lit and stay lit until you hit the Hawkeye ramp 3 times - therefore you don't have to light each ball lock in order to lock, like in LOTR. Light all 4 lane inserts, and you can lock all 3 balls.
There is room for a plastic and the light/s there, just not room for the huge Loki plastic, whose cape is totally blocking the Fury target. So, I will probably look for a clear plastic to re-rivet the lights onto, and install something less conspicuous and blocking in place.
// Error: Image 60686 not found // // Error: Image 60687 not found // // Error: Image 60688 not found // // Error: Image 60689 not found // // Error: Image 60690 not found // // Error: Image 60691 not found // image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg
