I need a pic of under the pf of the Vertical up kicker All the way left middle of the pf, its the kicker that
Pops the ball into ramp during multiball.
It would be a awesome duty to a fellow pinsider.
Well the vuk on the left was missing the cup when I got it causing the balls to pile up and it took several kicks to get the ball in the ramp.
I bought the vuk kit from Marco and installed it and there is a switch that sits in the same hole as the vuk cup, that switch lever is in the way up the cup and I was wondering if that was the reason the cup was missing in the first place.
The lever and the cup don't fit inside the hole. I was wanting to see someone else's to see if that switch is supposed to be there or if it was moved. If I take the cup back off then it works but the balls pile up again.
I checked the manual and there isn't a pic of under the pf.
It's a trivial problem but I'd like to get it working properly
