So my long opto beam for mist (switch 82) is not working again. Previously, it was the L1 inductor on the 24 switch opto board. I replaced that and it worked great for a month or so. The L1 inductor is still on the board, so it's not that. (previous thread if interested: http://pinside.com/pinball/forum/topic/bsd-opto-assembly)
Here's the list of current symptoms:
--In switch edges test, a hand across the beam does not register.
--Using a digital camera, I can see that the transmitter led is on.
--Using a tv remote control pointed at the receiver does NOT register.
--Suspecting it was a bad receiver, I replaced it. Still does not work.
--In a move of desperation, I reflowed all solder points on the board. Still nothing.
That's about the limit of my skill set. I've searched the forums far and wide, so far no one seems to have my same dilemma. I own a multimeter, but have little idea how to use it. I'm about to break down and order the redesigned one from homepin.com. Before I go spending another $100 on this BSD, I thought I'd reach out to pinside....help!
Thanks,
Spray
