AC/DC names
Started 1 year ago by absocountry2 in forum Stern Pinball.
Forum » Stern Pinball » Topic
AC/DC names
  • Started 1 year ago by absocountry2
  • Latest reply from absocountry2
  • 180 karma points were scored in this topic
Topic poll
  • poll:
    AC/DCBIB & AC/DCLTBR : (5 votes)
    26 %
    AC/DCBIBLE & AC/DCLTBRLE : (4 votes)
    21 %
    BIBLE & LTBRLE & PRO & PREM : (10 votes)
    53 %
    AC/DCLEBIB & AC/DCLELTBR : (0 votes)
  • Games linked to topic
      OK, I keep seeing people use BIBLE and other names for the Back in Black AC/DC pin. My understanding there is no official naming for the pins, so I wanted to start a poll and see what most people actually think. I will tell you my vote and justify my view.
      I am choosing option 1 because I think it fits the best. I am going to use AC/DCBIB as my example. The second option is not as good as the first because putting LE in with BIB is just duplicating the name. BIB is already a LE pin. To say LE implies that there is a non LE AC/DCBIB pin. There is just one of each version for a total of four versions. Do we really need more?
      The third option has a couple faults with me. See the above paragraph for my problems with using LE with BIB for the first fault. My second issue is the obvious use of what BIBLE actually spells. I am not one to be hyper sensitive, however I feel using BIBLE to describe a version an AC/DC pinball machine could offend others for obvious reasons. I mean the songs are not really what the actual Bible teaches. Another point to be made against this option is that using this as the name would mean you would have to use PRO and PREM for the other pins and that does not work without AC/DC in front of it.
      The fourth option I added based on the name from Stern. On Sterns website they call the AC/DC pins "AC/DC Limited Editions: Back In Black & Let There Be Rock." This option fails due to having LE in with BIB or LTBR.
      I am not picking on Stern, just the names people are using. With all of the above reasons, I do have a problem with WOZECLE as well but I do not want that in this thread. This is in the Stern sub-forum. WOZ naming can be a different place and time.
      What do you guys think the name should be? Feel free to support your option, you might have the point that will turn the tables.
      I don't sweat the acronyms. The shear number of different games per title is going to make this crazy across the board.
      I will go with AC/DC or AC/DC LE myself if they want more info they will ask =-)
      As for the other thread EC is not needed as LE is EC for that title.
      just my thoughts have a great day.
      That is what I though but I thought LE could drop and leave just EC.
      BIBLE & LTBRLE are Good. But the Prem- and Pro will probably be listed AC/DC Prem / Pro.. In the Top 100 Here, Due to Rating , There's Really Only 2 P/F's , Pro's & Prem's/LE's .. I hope they are Split up !!
      How many premium AC/DCs are they making?
      AC/DC Pro vs Prem/LE had goddamned well better be split up in the machine listings! You can't add a whole miniplayfield to a machine and call it the same machine!
      I thought they were making as many Prem's as they can sell (hence why it's not a "limited edition").
      I'd say BIBLE (or more likely ACDC BIBLE). Nobody who finds that offensive would be able to stomach the ACDC machine anyway.
      Oh I understand there may not be an initial limit but I figured they had some set production amount upfront? Maybe not, curious if anyone knows for sure.
      I think they are limiting the LE versions to 300 each, anybody verify?
      I'll stick to what it currently is now.
      I asked SR the same Question in Texas.. He said they Will be made into 2013 and as Long as they Keep selling.. ( Not, what I was wanting to Hear !! )
      I didn't see my choice. I'm going with BIBLE and LTBR (and of course ACDC Pro). Admittedly inconsistant, but seems right to me.
      -Craig
      It does not make sense to leave the LE in BIBLE and not call the other LTBRLE, and I ran out of options to use. You pointed out it was not consistant though.
      My biggest concern is trying to figure what pins are what in the future. I have dealt with inconsistant names in other things trying to get parts so I figured I would try to head the inconsistancy off now. I figure it would be easier than trying to explain all the different names to grandkids in the future or even trying to order parts in the future.
