256x64 dmd inside batman forever?
Started 1 year ago by brandonmilam83 in forum All Pinball.
Forum » All Pinball » Topic
  • Started 1 year ago by brandonmilam83
  • Latest reply from goatdan
  • 450 karma points were scored in this topic
Tags
No tags yet.
    Batman Forever calls for a 192x64 big dmd dot matrix, but is it possible to use a 256x64 dmd?
    BVM
    This post has 1 tilt warning and has been hidden, according to your tilt warning setting. You can unhide this post
    Retired Pinsider
    Batman Forever.. Came with a 192x64 pixels from factory.
    Surly a 256 will not fit.
    was thinking if the plugs were the same i could modify it in someway to fit
    BVM
    Retired Pinsider
    Sell the table as spares.. I would.
    BVM
    Retired Pinsider
    or attempt to get it fixed. It's not a long lasting fix.. but could help you out for a month or 2.
    where can u send it off to, to get it fixed?
    BVM
    Retired Pinsider
    ..I'm from England & have a contact who can sometimes fix DMD's
    Try using the search at the top of the forum page.
    BVM doesn't have a clue what he is talking about, as usual. BF is a great machine. The large display is pricey, and the issue with these segas that had it. I have a new extra one I got off a guy on RGP when I had a BF for a back up. I keep meaning to sell it.
    I bought it for $350, you can have it for that plus shipping if you want it. I was keeping it for another large DMD machine if I came across one, but that is unlikely at this point. I believe through MAD is $450 plus tax and shipping. For an extra $50, I'll throw in another one I have with two lines out and some minor gassing. That should keep you safe for a long time.
    As for repairs, if there is a line or two out, that is one thing, but the repairs would still like be $100-$200. If it is gassing, there is no repair. Even with a line out, it may be in your interests to buy another anyway, as I don't expect them to be available for too many more years.
    how much is shipping?
    I don't know. I don't sell much, I'm a bit of a hoarder. I can find out if you want. pm me with your address, and I'll call and get a price.
    What is wrong with yours anyway? Is it gassing?
    Are you sure the display is bad?
    I've had two Batman Forever's that the display liked to blank out on because of inconsistencies in the power supply. (Not a solid +5v through the connector as it ages).
    There is a fix, and a way to re-wire it. http://www.sternpinball.com/downloads/sb106.pdf
    Again, this might not apply to you. Generally this helps the oversize displays that are "blanking out" sporadically.
    Just worth a shot before you invest a lot into a new display.
    Batman Forever is a really good game. It is certainly worth trying to get fixed.
    Pete
    when i bought the pinball machine this year, the guy said that it didn't light up, i brought it home and it still never came back on, its just black, the machine it self works perfect, and i checked the fuses, i took them all out and used a volt meter and they are all fine
    Ok, you may just have an issue with the PS or the 5v connector on the DMD controller may need to be repinned. I'm guessing PS issued, as the latter still gives you the rom version, then goes black.
    You will want to explore this before spending the $$$. Look at the PS where the connector for the DMD connects. Check all the voltages on the DMD, and if one is missing back track from there.
    Agreed.
    A completely 100% dead DMD could certainly lead me to believe that the problem is elsewhere. (Unless the DMD is visibly damaged).
    Sure, if may truly be dead...but I'd want to track down some more info before I bought a new one.
    Pete
    the dmd never powers on any at all, the machine it self, lights etc do, the dmd always stays black from when u cut the machine on til hours later when i cut it off, it never cuts on not even for a sec
    You will need to verify all the voltages to the DMD. Do you have clay's guides? I'm on my work laptop now, so I can't post a link.
    - If you're missing a voltage, it may be an easy fix.
    - If the voltages are all there, it may be the DMD controller board (they can go as well)
    - It could be the ribbon cable from the DMD controller to the display.
    These are things you want to check.
    It's on Ebay for $385 last I saw. The game is collectable and a solid pin. "part it out"??? "$300 table"?? No wonder everyone tilts this guy.
    Send me the details on this £275 BMF. I'll buy it.
    BVM
    Retired Pinsider
    The seller has just emailed me he let it go for £250.
    You guys kind of missed the boat on this. There were about 20 of these large 192x32 displays on ebay in April for $50 each. All tested and working. And it took them a while to sell them. They are all gone now though.
    BVM
    Retired Pinsider
    I take it you didn't buy them?
    I also missed the boat...
    WTF is the deal PP ? Honestly if you know please explain the difference in pricing UK -US . I know you are not making that shit up, so PLEASE explain to us the what and why of it.
    But for the OP, kudos, when I read the topic I thought it might be. You just wanted to see if you could get that other DMD in the machine, get it to display, then figure out how to get everything back on, right? Grrreeeat idea, assuming you can source that other display for sub $50. I would try it out man, you not going to hurt the other display any more than it is by removing it. You could ruin the new one . If you decide to try it out, give us an update.
    Wow I would have bought one of those in quickly!
    BVM
    Retired Pinsider
    pinballlooking said:
    cfh said:You guys kind of missed the boat on this. There were about 20 of these large 192x32 displays on ebay in April for $50 each. All tested and working. And it took them a while to sell them. They are all gone now though.
    Tell me about it.
    Clay - I'm assuming you meant the 192x64, and if so, wow, that would have been great for anyone with one of these to ensure longevity.
    BVM said:
    you'll find that a £300 (Three Hundred POUND) table equates too $471.91
    You know, I should have you round up a container of £250-£300 Batman Forevers and ship it to me in the states.
    Holy smokes...I'd make a crap-ton of money!!
    Pete
    12 months ago | # !! © |
    Ok, thanks Robin for re-opening this post for the op. Again, send me your email, I'll send you what you need to check the voltages at the display, and we will go from there, back to the PS, and determine what is wrong.
    I don't think anyone mentioned this but if you somehow could connect the larger DMD wouldn't you need different ROMS for the extra dots?
    Check the Sega service bulletins on Batman Forever. There was one that gave you a better power feed to the DMD itself. When I got mine, the DMD wasn't working and I did that and it has been just fine ever since
